Cool Back-up Light Mod for Z's
I ordered two 19 led bulbs for my Back-up lights just to see if they would make a difference. I got them in today and in a rush it put them in, I forgot to take a before pic , but the after pics speak for themselves.
Look how bright they are
They are from http://www.autolumination.com/ under the 3157 back-up and taillight section
I did replace the outer brake lights, but it didn't make a big difference
And don't put them in the blinkers, they don't work
Cool, to bad its only for the Z...
I think reverse lights SHOULD be bright because when you are backing up in a rural area you can't see shit - or at least I can't...
- Jeff L.
I think they will work in yours there will just be 4 ? of them, I think
The pics look like they light up most of the light, but in real life they almost always just have 2 bright 1-2" circles on the lens. Are the pics really accurate to real life?
That site is pretty cool though, the Light Towers look very interesting.
During the day they look like this, but the night pics are true to real life. The back-up light cover diffuses the light , but you could get some that shoot light to the side so it would fill up the fixture
Here is a pic at night with the flash on
I have 3157's all the way across my back end of the Z and 4 led red 194 bulbs on the corners. My blinkers work fine. I believe a normal 3157 is a dual filiment bulb. The 3156 is the single filiment bulb. Anything called 3157 should be able to blink. At least mine do. But i did have to get a heavy duty LED flasher made for semi's to handle the amount of led's. Each of my 3157's have 12 led's...plus the 4 led on each rear corner....blus my 2- 12 led amber signals up front and my 2- single led corner amber's. That's alot of led's... :D
Pep boys has some brighter lights that I have in my car. They work good, and they sell for I believe $10.
Nice, I need to get a set. My friends new Crossfire has some bright ass backup lights. Was like looking at headlights or something.
they make these 150 watt back up bulbs that i have in my suburban i think they also will fit in my car so i'll check this out :wink:
Yeah, I've seen those halogen replacement backup bulbs. I think they'd be a lot brighter than LEDs, but also a lot hotter, suck a lot more power, and will still burn out eventually. Backup lights aren't ever on for very long so I don't think any of that is a big problem. I wouldn't leave the car in reverse too long with halogen backup bulbs though, it could warp or melt the reverse lights.
my suburban's tail lights haven't melted yet. so i don't think the bulbs will ever be on long enough to melt my tail lights. i think i'm going to buy a set and put them in. i'll let everyone know how it goes :)
1993 OLDSMOBILE Cutlass Supreme (2-door model)
Low beam headlamp
H4351
High beam headlamp
H4352
Parking light
3057A
3057AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
3057ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
3057A
Rear turn signal
3057
3057LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
3057
Stop light
3057
High mount stop light
3155LL
577
891
Fog/Driving light
885
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3057
Front sidemarker
24
Rear sidemarker
194
Ash tray
194
Glove box
194
Map light
194
212-2
561
Dome light
212-2
561
Step/Courtesy light
194
212-2
Trunk/Cargo area
920
Instrument-general
168
194
37
74
Hi-beam indicator
74
____________________________________________________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
DAMN!!! Thats quite a few!
that would be a 1000.00 dollars to convert the car over to complete LED. but think of the power it would save! a LED flashlight has a huge battery life over fulliment light bulbs! The power savings would be enough to make up the power usage of a big system!
