1990lumina Posted May 5, 2005 Report Share Posted May 5, 2005 If I knew what all is needed I might be able to check some of the yards around here, however they will charge way to much for it I'm guiessing...and there aren't any "You pull it" yards anymore...and it is difficult described what all you need, and don't want broken when the guy is tearing it off the car... I wish people were more honest so we would (in my area) still have some "you pull it" yards - Jeff L. Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted May 5, 2005 Report Share Posted May 5, 2005 I see canadian W-bodies in the yard here occasionally. I got in some GP and the speedo went to 220 or something and I was like "WTF" Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted May 5, 2005 Report Share Posted May 5, 2005 any way some1 w/ a non DRL W to get them? GM makes an aftermarket DRL module. I can get a part # when I get home. It's about $40. It's not nearly the quality of a factory module though. It's just a plastic box with about 1.5ft of wire coming out of it. The wire is directly soldered to the circuit board. Pretty cheap thing, but it does have an adjustable shut off delay of 0-90 seconds. Unfortunately, no external control so you have to set it on the box itself. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted May 6, 2005 Report Share Posted May 6, 2005 The GM add-on DRL/Twilight Sentinel module is p/n 12370511. According to the service manual, the DRL module and diode assembly are located near the LH courtesy light. Quote Link to comment Share on other sites More sharing options...
cutlsp Posted May 6, 2005 Report Share Posted May 6, 2005 cool now i'm gonna add drl/twilight thingy to my 88 cutlass Quote Link to comment Share on other sites More sharing options...
