Rabbi Posted May 2, 2005 Report Posted May 2, 2005 can anybody point me to a good site about exhaust's ? mainly i need to know, does bigger pipe = louder exaust ? Quote
topless94style Posted May 2, 2005 Report Posted May 2, 2005 No pipe = loud exhaust I think once it gets big enough, the tone starts to deepen and it doesnt get as loud. Quote
Rabbi Posted May 2, 2005 Author Report Posted May 2, 2005 well duh about the no pipe lol but what i mean is, What is the diffrence between 2" , 2.25" and 3" piping? Will this matter how my car sounds? Im going to throw some 2" magnaflows on it next week, But before i do i want to know if i should replace more of the pipe with it, But if it wont really make a diffrence in the sound of the car i wont touch it. Quote
19Cutlass94 Posted May 3, 2005 Report Posted May 3, 2005 sometimes making the exhaust pipe bigger will actually lose power and if you have the 3100, 2.25" is all you need, if you start going much beyond that, you will start loosing power, but mostly if you want that "tone" you can remove the resanator (however you spell it ) and put a muffler that suits your choice Quote
5speedz34 Posted May 3, 2005 Report Posted May 3, 2005 Stock is 2.25", this is the best set-up by far for Z34's. Stock 3" downpipe, 2.5" piping, hi-flow cat (or no cat but it'll stink), a resonator of some kind (it'll pop otherwise), and Magnaflow mufflers, with a exhaust tip of your choice. Quote
Rabbi Posted May 3, 2005 Author Report Posted May 3, 2005 2.25" is the stock size???? i was told its 2" ????? its a 91 z34 with the stock mufflers and a 3.4 motor. Quote
Crimson Fury Z Posted May 3, 2005 Report Posted May 3, 2005 mine measured at 2.25, and i got one of the 2 magnaflow mufflers (#12246, aluminized 2.5 in/outlets)and awaiting the 2nd one. then 2.5 mandrel piping from the cat(high flow, silly!) to the mags. Quote
GOT2B GM Posted May 3, 2005 Report Posted May 3, 2005 I just recently measured the factory pipes on my 93 Z34 and came out with the following. 2.5" from the motor to the cat 2.25" from the cat through the resonator to the Y 2" from the Y to the mufflers I'm getting my exhaust done very soon. I plan to do 2.5" from the motor to the Y, and then 2.25" from the Y to the mufflers. The components (already purchased) I will be using are: Magnaflow Hi-flow stainless cat 2.5" Vibrant stainless resonator 2.5" (2) Magnaflow stainless mufflers offset/center 2.25" (2) 04 GP tips (the ones everyone seems to hate, but I like them) Just have to get it to the exhaust shop and get the stainless piping bent up(mandrel) and everything installed. Quote
Aaron Posted May 3, 2005 Report Posted May 3, 2005 The above system is perfect for most Z34s. 2.5" motor to Y, with a resonator, and then 2.25" to the tips with dual Magnaflow mufflers. Quote
slick Posted May 3, 2005 Report Posted May 3, 2005 The above system is perfect for most Z34s. 2.5" motor to Y, with a resonator, and then 2.25" to the tips with dual Magnaflow mufflers. I, personally, will be going just a bit larger in some area's. Quote
Aaron Posted May 3, 2005 Report Posted May 3, 2005 The above system is perfect for most Z34s. 2.5" motor to Y, with a resonator, and then 2.25" to the tips with dual Magnaflow mufflers. I, personally, will be going just a bit larger in some area's. "most Z34s." Your car, becuz of the tranny/enigne work, would be best with a 3" split into dual 2.5s, and the same system would be good for my car (Tony's) as well. Quote
88Regal Limited Posted May 4, 2005 Report Posted May 4, 2005 2.25" is the stock size????i was told its 2" ????? its a 91 z34 with the stock mufflers and a 3.4 motor. Dude, my new cavalier came stock with 2.25in piping.... The Z should at least be that, right? Quote
topless94style Posted May 4, 2005 Report Posted May 4, 2005 My new one goes like this Stock exhaust manifolds 2.5" Ypipe(crossover) 3" downpipe 2.5" into res into Ypipe 2.25" Ypipe into 2.5" mufflers into 3" tips Quote
DrRodey Posted May 4, 2005 Report Posted May 4, 2005 I just re-redid the exhaust on the GTP. 2.5 the entire way, highflow cat, no resonator, dual Borla high flow muffs, just need to find some decent tips yet.. Little louder then I though it would be but is sound meaner then hell. I'm thinking some twin resonator tips will mellow it out just perfectly. Dan. Quote
Rabbi Posted May 4, 2005 Author Report Posted May 4, 2005 ok so is the stock pipe before the muffler 2" or 2.25"? ive heard about 10 people say both ways im lost now Quote
