What can i swap into my grand prick?
im assuming that my engine will not last more than a few years, so i would like to know what i can replace it with (besides another slow@$$ 2.8 ). the 3.1 isnt too much of a step up either, but thats a perfect swap, right? is there any other engines that are easy swaps (newer grand prick engs, turbo engines, non-wbody engines)? TIA
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
  • Fat Ryan
    19
  • slick
    13
  • gp90se
    6
  • digitaloutsider
    3
He did, all he found was a bunch of assholes telling him to search.
2.3 DOHC
2.8
3.1L Turbo
3100
3.4L DOHC
3400
3800
3800 S/C
The 3100/3400 will be a pretty much direct swap into your car as well, and would definately be worth the power gains from it. Hell, even the 3.4 DOHC is almost a direct swap, just gotta move some plugs around some.
If he had the 2.8 before, I don't think the cradle will have the provisions for the 3.4 DOHC's motor mounts.
You'd need a new subframe for basically anything but a pushrod 60*.
Hmm... good point. If it is the older style, it might not work. I think when they started using the 3.1 you could swap in the 3.4 as well.
4g65
LS2
K/B 5.4
a newer (91-96) subframe will bolt in so a DOHC motor will be a very simple swap.
ls2? are you fu(king kidding me. theres not a chance in hell an ls2 could ever fit in these small @$$ cars.
a 305 fits with plenty of room to spare, the LS2 is a little wider but i believe shorter then a good old v8s
The 3.4 was wider then the 305....
ok, well im sure if it does fit, theres a ton of mods. im looking for an easy swap
bach, bland :twisted: (yea yea im still finishing mine)
go find a H.O. quad 4 and getrag, 180 horses and i think it bolts in
He's looking for something easy. This would require swapping the wiring as well(it's not hard, but not a direct drop in and go).
so will it work or not? and what car are they from?
For simplicity of the swap, go with the 3100 or the 3400.
3.1 Turbo, or a 3400, or a 2.3 Quad 4 HO, came in Grand Ams 92-95, and some W's, I wouldnt do a DOHC, cause there altenator/Timing belt issue
Out of those, again, the easiest swap would be the 3400. 3.1 Turbo would have a lot of mechanical and some wiring work involved. 2.3 Quad 4 would be a ton of mechanial work and a ton of wiring.
so the 3.4 would fit perfectly into my 89 2.8?
Once again, You'd have to swap your subframe to the '91-96 3.4/3800 one.
This topic is now closed to further replies.
