Jostran911 Posted April 30, 2005 Report Posted April 30, 2005 It appears that the swap is straigt forward as far as mounting and all what about wiring? do I use the sensors etc from the 92 3.1 on the 94 3.1? thanks in advance Jack :?: Quote
Aaron Posted April 30, 2005 Report Posted April 30, 2005 It appears that the swap is straigt forward as far as mounting and all what about wiring? do I use the sensors etc from the 92 3.1 on the 94 3.1? thanks in advance Jack :?: What are you talking about? It sounds like a 94 3.1 swapped into a car that originally had a 92 3.1, correct? There are a lot of posts here, you can't just say "the swap," cuz then I relate it to swapping a 3.4 DOHC into a Fiero. Quote
White93z34 Posted April 30, 2005 Report Posted April 30, 2005 everything ought to be the same, just double check between both engines when you have them out of the car. Quote
5speedz34 Posted April 30, 2005 Report Posted April 30, 2005 You're going from a 92 3.1 to a 94 3.1? It's not a 3100 right? if so everything will be the same Quote
Jostran911 Posted May 4, 2005 Author Report Posted May 4, 2005 it is a 3100. i have read the FAQ section and the swap is suppoed to be easy Just curious on wiring, what would be difference on 3100 over 3.1 I know coil pack location is different. Most of the sensors look the same curious thanks Quote
slick Posted May 4, 2005 Report Posted May 4, 2005 Actually, there isn't much of a difference between the wiring. You will have to use the 3.1 injectors, and I keep wanting to say the fuel rail as well, but I could be wrong on that. There are a few plugs that you will have to change, but thats no biggie. Otherwise, it is pretty much a direct drop in and go. Quote
Brian P Posted May 4, 2005 Report Posted May 4, 2005 you have tro lengthen the DIS wires, I think the TPS wires, you need to change out the accelerator cable with one from a 3100 car, use a 3100 p/s pump, modify the p/s return line (lengthen it and it needs to curve differently), and you need to use the 3100 exhaust downpipe and mate it to your existing exhaust. You need to use the 3100 fuel rail so you'll have to adapt to the 3100 "quick connect" body-side fuel lines to have this. I'm sure there's more... Quote
Jostran911 Posted May 10, 2005 Author Report Posted May 10, 2005 any suggestions on the best way to adapt lines for fuel? thanks Jack Quote
