93CutlassSupreme Posted April 29, 2005 Report Share Posted April 29, 2005 hey guys some dipshit shattered my rear window and i'm trying to replace it myself...but.... i've gotten most of the window pieces out, but how do i remove the adhesive around the perimiter of the glass? i can't get the outer ring/perimiter/edge of glass where it meets the weatherstripping/metal window frame and adhesive off the car. i tried cutting it using wire like my service manual says, but the wire keeps on breaking, and a knife barely cuts it. a guy i work with told me about a tool that glass shops use to remove windows, how can i get this tool? or, how can i get this shit off? thanks Quote Link to comment Share on other sites More sharing options...
GP1138 Posted April 29, 2005 Report Share Posted April 29, 2005 Shit man. I'm not sure of the answer to your question, but I'm sorry to hear that, that's bullshit. Quote Link to comment Share on other sites More sharing options...
z34_nut Posted April 29, 2005 Report Share Posted April 29, 2005 ugh, what a pain in the ass. I'll get into it when i get off the phone. I was woundering where you went. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted April 29, 2005 Report Share Posted April 29, 2005 Get some thick wire like piano wire and get it into the adhesive shit, and you should be able to get it off. That's what we did for my corner window and it worked great. Quote Link to comment Share on other sites More sharing options...
z34_nut Posted April 29, 2005 Report Share Posted April 29, 2005 The tool is a power tool, cuts through some serious shit. It takes a skilled hand... Hrm, mabey if you did a serch on google, it coudl give you detailed instructions on how to do it? Why not, they have every-other peice of info. Quote Link to comment Share on other sites More sharing options...
White93z34 Posted April 29, 2005 Report Share Posted April 29, 2005 look for stores that sell a very long handled tool with a prety sturdy razor blade on it. it works great with i pull windshields for just cutting up the adhesive. then get some heavy duty piano wire, that makes the job prety easy too. all is best if the adhesive is warm, a nice sunny day and it will come right out. otherwise try a hairdryer or heat gun. Quote Link to comment Share on other sites More sharing options...
1990lumina Posted April 29, 2005 Report Share Posted April 29, 2005 Thats some good advice man!! Quote Link to comment Share on other sites More sharing options...
White93z34 Posted April 29, 2005 Report Share Posted April 29, 2005 and for what its worth you may want to leave some of the old adhesive for the new to stick to. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted April 29, 2005 Report Share Posted April 29, 2005 Maybe this will work? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=303&item=4376156962&rd=1 Yeah, a power tool sounds like it would be easiest. Definitely leave some old adhesive for the new to stick to, and use urethane adhesive. Don't use butyl. I think there are warnings in the service manual not to use butyl, but just in case there aren't, I'm warning you now. Quote Link to comment Share on other sites More sharing options...
jeremy Posted April 29, 2005 Report Share Posted April 29, 2005 sorry to hear about your luck Kevin Quote Link to comment Share on other sites More sharing options...
Dannymik Posted April 29, 2005 Report Share Posted April 29, 2005 Kevin the tool that Shawn linked you to works well for front windshields that have massive curves in them. The hardened bullshit your trying to cut through is urethane and a primer on the very inner ring. The best tool is what Chris(white93z34) stated....here's a link to what we used at Safelite http://www.pipeknife.com/pipeknife.asp That will give you adequate leverage that you'll need, but very careful that you don't end up a bloody mess doing it! Goodluck Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted May 7, 2005 Author Report Share Posted May 7, 2005 thanks for the help guys, Murray's had a tool just like the one Shawn linked to it still sucked ass using that tool but it got the job done Quote Link to comment Share on other sites More sharing options...
