JJ77 Posted April 28, 2005 Report Posted April 28, 2005 The rear end on my lumina is sagging so I was thinking about lowering the front so that it would be lower than the rear. What do you think ? Quote
EurosportZ34 Posted April 28, 2005 Report Posted April 28, 2005 i don't see what ya'll are seeing...they look fine to me! Quote
z34_nut Posted April 28, 2005 Report Posted April 28, 2005 Lower the front, god i hate the stock ride height in the front. BTW nice clean car you got! Quote
Aaron Posted April 30, 2005 Report Posted April 30, 2005 Lower the front, god i hate the stock ride height in the front. BTW nice clean car you got! You mean old stock. They aren't like that from the factory, it is just years that do it. I think you should, I was considering doing it to mine. On a side note, HOLY UBER-PERFECT WHEELS BATMAN!!! Quote
JJ77 Posted May 1, 2005 Author Report Posted May 1, 2005 On a side note, HOLY UBER-PERFECT WHEELS BATMAN!!! They're stock but I keep'em clean. By the way, what springs should I use when lowering Quote
terryk2003 Posted May 2, 2005 Report Posted May 2, 2005 i personally don't think the front needs lowered, BUT...if you wanna do it i don't think it'll look bad either...so, i dunno...it really doesnt look bad the way it is though! Quote
Guest Posted May 2, 2005 Report Posted May 2, 2005 I can hardly notice it from the pics, but if you want to lower the front go ahead and lose an inch. Quote
5speedz34 Posted May 2, 2005 Report Posted May 2, 2005 I think Intrax? is a little bit lower that the Suspension Techniques one? Quote
GnatGoSplat Posted May 2, 2005 Report Posted May 2, 2005 Intrax is supposed to be a little lower, but in real life I think their drop is no more than the ST's. I can tell the front needs dropped more though, there's definitely more tire gap on the front. It's just not real noticeable in the first pic because the rear tires are more tucked so the fender is causing a shadow on top of the rear tire giving the illusion of equal gaps. Quote
JJ77 Posted May 3, 2005 Author Report Posted May 3, 2005 Would someone care to give me a link where I can get some Intrax or ST springs Quote
GnatGoSplat Posted May 3, 2005 Report Posted May 3, 2005 jcwhitney.com has the ST springs. Plug in 95 Chevy Monte Carlo as your car. Quote
JJ77 Posted May 3, 2005 Author Report Posted May 3, 2005 So these will fit http://www.jcwhitney.com/autoparts/Product/tf-VehicleBrowse/s-10101/Pr-p_Product.CATENTRY_ID:2005865/showCustom-0/p-2005865/N-200728464+111+1995+600003409/c-10101 and I should get about a 1 1/2 inch drop out of them right Quote
Jcrow Posted May 3, 2005 Report Posted May 3, 2005 What do you need to install those? I have some coil spring compressors. Any special tools? Quote
GnatGoSplat Posted May 3, 2005 Report Posted May 3, 2005 I had the entire knuckles out... I guess you can say special tools are recommended to get the knuckle out, I have the Kent Moore outer tierod and balljoint tool which pops those out real easy without hurting them. Once you have the knuckles out, a set of coil spring compressors is all you really need to put the springs on. You can probably do it without pulling the knuckles out, but it seems like that might be a bit of a hassle. Quote
Jcrow Posted May 3, 2005 Report Posted May 3, 2005 How about the strut? do you have to loosen the strut or any thing? If I do this it would be a good time to get new control arm bushings too Quote
GnatGoSplat Posted May 3, 2005 Report Posted May 3, 2005 No, you can leave the strut in the knuckle, but be aware the strut and knuckle are built into 1 assembly. Quote
JJ77 Posted May 4, 2005 Author Report Posted May 4, 2005 Just ordered them should be here in 7-10 days, Thanks for the advice guys Quote
z34_nut Posted May 4, 2005 Report Posted May 4, 2005 Just ordered them should be here in 7-10 days, Thanks for the advice guys nice! I want to see some pics when its done... theres just some-thing about your car that I'm drawn to! Quote
