Vegeta Posted April 25, 2005 Report Posted April 25, 2005 I raised my idle speed a bit and the car got quieter. I think the stock idle speed on these cars is set too damn low. Especially the 3.1 cars. Quote
Grand Moff Joseph Posted April 25, 2005 Author Report Posted April 25, 2005 how do you raise the idle speed, and how can you tall what the rpm is without a tach in the car? Quote
19Cutlass94 Posted April 25, 2005 Report Posted April 25, 2005 Ive had the FFP monts is for a while and i duno if it happens to everybody but when I shift from neutral to drive, the idle drops low and it sounds like the engine is going to stall but it doesnt Quote
Grand Moff Joseph Posted April 25, 2005 Author Report Posted April 25, 2005 my car did that before I put the new bones in anyway. When I shift into gear, the rpm drops like a rock, then comes back up again. Is that a problem too??? Quote
Vegeta Posted April 25, 2005 Report Posted April 25, 2005 Have to change the idle speed in the computer with a chip. I program chips so yeah, pretty simple for me to do:P Quote
Grand Moff Joseph Posted April 25, 2005 Author Report Posted April 25, 2005 oh you do, eh? Could you elaborate on what these chips are/do? Quote
19Cutlass94 Posted April 25, 2005 Report Posted April 25, 2005 if I got a chip from FFP, would that fix it? Quote
Grand Moff Joseph Posted April 25, 2005 Author Report Posted April 25, 2005 now that you mention it, how do you buy their chips? They are not listed as a product on their page... Quote
rudefyet Posted April 25, 2005 Report Posted April 25, 2005 Mr. Vegeta sells them through 60degreev6.com now not sure if he's got the store operational yet or not...but check http://store.60degreev6.com Quote
maybe2fast Posted April 25, 2005 Report Posted April 25, 2005 just check the lower liquid filled mount Quote
juicedlumina Posted April 26, 2005 Report Posted April 26, 2005 I think i remember having two lowers replaced on my 3.1 long time ago. At a store theyre 50$. One they said was really a bitch to change and cost 200$. My tranny went out later and while the cradle was down they changed it for free. So 200$ at that shop your looking at prob 100$ for their "genuine" gm mount and then they charge like $80+ an hour to do it. Quote
Grand Moff Joseph Posted April 26, 2005 Author Report Posted April 26, 2005 sounds like going to the auto parts store and getting the parts from there, and doing it myself is the best option. Quote
19Cutlass94 Posted April 26, 2005 Report Posted April 26, 2005 thats quite the hit right there to have that done Quote
digitaloutsider Posted April 26, 2005 Report Posted April 26, 2005 if I got a chip from FFP, would that fix it? Ben doesn't make chips for 3100's. Quote
19Cutlass94 Posted April 26, 2005 Report Posted April 26, 2005 that kinda stinks but I guess Ill just have to live with that idle till I can get around to fixing it........ what would you have to do to change the idle anways? Quote
Grand Moff Joseph Posted April 26, 2005 Author Report Posted April 26, 2005 you have to change the idle via the car's computer, which means you need a custom chip. Quote
sonyman87 Posted April 26, 2005 Report Posted April 26, 2005 i dont know why people think thats normal. mine dosnt vibrate like that sounds like the idel is a bit low. Motors will shake and shutter when the idel is set to low. Quote
RareGMFan Posted April 26, 2005 Report Posted April 26, 2005 Can't you manually raise the idle at the throttle? Quote
sonyman87 Posted April 26, 2005 Report Posted April 26, 2005 Can't you manually raise the idle at the throttle? Yes remove the top plate above the throttle cable coil on the throttlebody and there should be a little screw next to it. just give it a few turns while the car is running until it quits shaking. this will have different effects as the car warms up and as the outside temperature changes. another way would to be adjust the IAC or makesure its working properly Quote
19Cutlass94 Posted April 26, 2005 Report Posted April 26, 2005 The only time my car shakes like that is when its running at operating temp, it wont shake at all when its cold even at idle, but what effects would manually changing the idle have? Quote
sonyman87 Posted April 26, 2005 Report Posted April 26, 2005 only effect would be idle itself. if you are on the gas then there is no difference. Quote
Grand Moff Joseph Posted April 26, 2005 Author Report Posted April 26, 2005 yeah, but I have no tach on my car, so can you hook something up to it to measure rpm? Quote
Stevo Posted April 26, 2005 Report Posted April 26, 2005 With 2 'real' jacks. You can jack up the car body with one and use the second to hold the subframe with the engine held in place with blocking (keeping it held solid in place). Remove both front wheels when its up and detach the control arms (kind of a pain in the arse). Lower the subframe after carefully detaching it... I and a fella I used to go to because he had air tools, replaced a whole subframe and rack in no time at all. Thing is we of course let the frame drop because we were switching it out with 2 jacks. Now my 88' sits in the driveway with what I KNOW is a busted lower mount. dammit. Quote
RareGMFan Posted April 26, 2005 Report Posted April 26, 2005 Yes remove the top plate above the throttle cable coil on the throttlebody and there should be a little screw next to it. just give it a few turns while the car is running until it quits shaking. this will have different effects as the car warms up and as the outside temperature changes. Yeah, I asked because I've done it before and was wondering why everyone was saying you'd have to get a chip just to raise the idle a tad bit. I don't care for how low most every car I've had idles, either, so I've raised them several times in the past. And I usually wait till they're up to operating temp before I do it (like after I get back from a drive, or so). Quote
