veritasz34 Posted April 24, 2005 Report Posted April 24, 2005 The front to rear manifold crossover(??) pipe in the Z34 really produces some radiant heat. This looks like it will degrade plastic/polomer parts over time.. Has anuone added a covering to this like header wrap or a sheild to reduce heat from straying??If so how were the results..Thanks in advance.. Quote
Aaron Posted April 24, 2005 Report Posted April 24, 2005 First of all it is already wrapped in a heat shield, and second of all, of all the Z34s I;ve ever heard of, I've never heard of anyone melting any parts. Quote
GOT2B GM Posted April 24, 2005 Report Posted April 24, 2005 I wonder if it might help reduce underhood temps a bit Quote
veritasz34 Posted April 24, 2005 Author Report Posted April 24, 2005 No you are right..It has not melted anything but with the increase in temp from the pipe I've replaced several plastic lines and components due to premature ageing from the heat..Reducing the underhood temp is exactly what I'm shooting for.. Quote
5speedz34 Posted April 24, 2005 Report Posted April 24, 2005 IMO-Why are you doing that? Just because some plastic lines over 10 years have worn out. If it's performance you won't see really any gains with a cooler engine bay unless you have CAI. Quote
