idler pulley bolt's Discontenued????
well i called the chevy dealership and the idler pulley bolts have been discontenued. Should i say fuck um and not even replace them??
I'd look at other dealerships. Theres 4 GM dealers in my immediate area. 1 lists some parts not discontinued and even showed me a warehouse count leaving the other 3 looking pretty stupid.
Guest TurboSedan
which idler pulley are you reffering too? i just bought a non-AC idler pulley for my Cutty and it came with the bolt.
the timing belt one.
The dealership quoted me on 393 dollars for the belt,pullys and bolts
is it just me or is that absolutly rediculus????
they want 83 bucks for the belt alone,Yet autozone has one for 35 (gatorback)
wtf gives?
Guest TurboSedan
just hit up a j/y or go to the hardware store if you know the bolt size.
If I remember right. My pullys came with the bolts. This was a year ago. You order the pullies and the bolts come with
As for Timing belts.... Pay for the damn GM orginal. Seriously it's not a part to mess with!
I would take that damn Good Year Gatorback over the gm piece for that money all damn day
The Gm piece may be a goodyear lower than gatorback line or gates rubber which is also a lower quality belt.
Doing timing belts I have found the Honda dealer Oem Gates belt to be lower in price than autozones lowest priced kelly springfield belt and 1/2 the price of the gatorback, I use the Honduh parts $17 for honda gates, $34 for Autozone Good Year Gatorback
I would also find out if Autozone has TIMKEN brand idlers bearings since Timken has been making the best bearings in america for over 100 years and the zone has been peddling them, Probably also half the price for a better or at the very least equivilent product. F GM and their alienate the consumer business plan
I would not say the same about low priced 1 year warranty Autozone remanufactured starters and alternators, The lifetime is fine tho. Po' folks cant afford and may not need the best on their beaters so Autozones Wal-Mart business model has obviously done them well, I see they now own AllData
  • 2 months later...
Autozone carries Idler Pulleys for $16.99 w/ bolt
Tensioners w/ pulley and bolts for $39.99
Ive used autozone and have had no problems with thier pulleys to-date. (On for over 60k miles)
