96 Grand prix...turn key, no start
My friend has a 96 prix 3100. He's been telling me about how he will turn the key and it doesn't start. If he goes back later it will. I used a napkin to wipe off the passkey sensors but it did it again. What would you suggest?
when it doesn't start, does is crank at all?
does he have a different key that he can try using?
he should also check the battery terminals to make sure they are tight, as well as the Aux terminal.
:werd:
Ditto what he said on checking the battery level and the terminals. If that all comes up clean, maybe check the starter?
:werd: x2
Just do what the guy in Florida did or where ever he was from. Get your .44 Mag and shoot the hood 6 times. :mrgreen:
To me It sounds like the pass key system is screwed up. Considering the age its probably wareing out. I think DiscoStud as an article on how to disable it.
trans range switch?
passive restraint module?
those were the two that were keeping my Z34 from starting...damn bastards! :lol:
  • 5 months later...
I'm having a similar problem with my '94 GP. It will crank, but won't start. I have replaced the theft deterent module twice, and the ecm is an A1 cardone reman. Any ideas?
take the shit out by hard wiring a comparable Ohm resistor in line. i could tell you which wire it is, but i cant remember...sorry...give me time to think about it
Have you had the ignition lock cylinder replaced?
Like I previously mentioned, read this article:
http://www.likeabigdog.com/column/VATS.htm
The wire Heza refered to is orange. More like it's an orange rubbery conduit with 2 tiny white wires inside. Basically what you do is snip the wires and put a resistor equal to the resistance of your key's pellet between the 2 wires...
The Park neutral switch connector was causing my Z to intermittently not start.
