fastbird232 Posted April 19, 2005 Report Posted April 19, 2005 Do the '96 GP five spokes have the same bolt patterns as '97-'02 GPs? Quote
dbtk2 Posted April 19, 2005 Report Posted April 19, 2005 Yes same bolt pattern and different offset. They will work fine on the new GP's however they will stick out a little farther than the regular 97+ GP wheels due to the different offset. They are wider however, allowing a wider tire. However, you can't take a 5 spoke from a 97+ and put it on a pre 97 because the offset goes the other way and the wheels hit the calipers. Shawn Quote
digitaloutsider Posted April 21, 2005 Report Posted April 21, 2005 They fit, and damn do they look good, IMHO. Quote
THe_DeTAiL3R Posted April 22, 2005 Report Posted April 22, 2005 I'd like to see that, with big meaty tires. Quote
Canada Posted April 22, 2005 Report Posted April 22, 2005 To bad the five spoke is only 6.5" wide........that means the big meaty tire can only be a 225. Quote
jeremy Posted April 22, 2005 Report Posted April 22, 2005 \ said: To bad the five spoke is only 6.5" wide........that means the big meaty tire can only be a 225. Quote
no1kicker Posted April 23, 2005 Report Posted April 23, 2005 I sold TGP rims to a 97+ GTP owner. He said they fit fine but since they were 8" wide, the rears (I think it was the rears) stuck out from the body and he was looking for some 7" wheels to try. Quote
dbtk2 Posted April 23, 2005 Report Posted April 23, 2005 \ said: To bad the five spoke is only 6.5" wide........that means the big meaty tire can only be a 225. The 97+ 5 spoke is 6.5, the 94-96 5 spoke is 7". And my dad has 245's on his '02 GTP with the stock wheels and no problems... Shawn Quote
