R Dubya Posted April 19, 2005 Report Posted April 19, 2005 I found that I am missing my vac line that runs to the canister from under the turbo. It was totally broken off and anything that I touched from halfway up crumbled in my hand, so I think that's why I am running rich and why I have a high idle. Anyone know what size tubing to use? I am going to replace the section that is bad, and use a connector for the two lines to meet, and then a new elbow on the canister. TIA!! Quote
mfewtrail Posted April 20, 2005 Report Posted April 20, 2005 Ryan, are you referring to the vacuum line going to the vacuum ball in the drivers side fender? When I replaced it on my SE, I took a piece of the broke line to the parts store with me to match up the size(I think I actually got a length of rubber vacuum tubing that would slip over the original line since mine broke off right before the elbow where it attaches). Quote
R Dubya Posted April 20, 2005 Author Report Posted April 20, 2005 Yeah, I suppose I could have erased this thread. The line that runs to the ball just snapped, I found it the other day. There was enough line remaining for me to just use a new elbow, which I think is 5/32". It fit fine, wasn't loose or easily removed. I think thats the correct size. Thanks Matt. Quote
