frank358fr Posted April 17, 2005 Report Posted April 17, 2005 Hi everyone, Following is a picture. Can you tell if it is this line that is leaking and brooken. The screw holding the line is brooken too. It seems to be leaking at this very place. Do I change just this portion, or do I have to change the whole line. Is there someone having a How-To manual available to do this job. Thanks. Edit: I just check the line and it the line for my right front wheel. I want to know wich line is it on my master cylindre. Thanks Frank Quote
95 3-4 Posted April 17, 2005 Report Posted April 17, 2005 Fixing busted rusty brake lines is pointless, I do not know which port on the MC it goes to but it cant be that hard to trace back to it Take an end to the parts store so you get the right size and measure what you need so you get enough line, you will probably need to join 2 piece of line so get the neccesary union at the store as well, if you get extra line it makes running it easier, no need to cut it just use the additional up in a wastefull way. If you kink a piece its junk so use a bender or a nice round shaped object with the right diameter for your desired radius Quote
frank358fr Posted April 18, 2005 Author Report Posted April 18, 2005 Ok, can I take the line in a junkyard??And How can I remove the old one?? Did someone have a How-To to remove the old line?? Frank Quote
