stlunatics2oo3 Posted January 22, 2003 Report Posted January 22, 2003 okay i am wonderin where my inside temp sensor or which ever it is since i have the outside temp and i believe i should have one inside and where is it and if i do where is it ???? and if it is broken where do i find another one ???/ the vehicle is a 89 2 door cutlass sL with climate control Quote
91CuttyConv Posted January 22, 2003 Report Posted January 22, 2003 If your looking for the temp sensor that works with the climate control it is under the glove box. Looks like a very small vent. Jason Quote
eclipse5302 Posted January 22, 2003 Report Posted January 22, 2003 There is no display of the inside vechicle temp. That temp sensor under the glove box is for the climate control to control the inside temp. But the temp it reads is not displayed on the climate control. Jason Quote
Brian P Posted January 22, 2003 Report Posted January 22, 2003 I'm going to do a little probing around with the multimeter and see if the outside and inside temp sensor have the same resistance at the same temperature. IF SO, then I'm thinking of hooking up a switch where I can go from the outside temp display to inside display on the "out temp" function. I'll let you know when I get off my lazy butt and do it! Quote
eclipse5302 Posted January 22, 2003 Report Posted January 22, 2003 I'm willing to bet they will be very close. I think that'll work just fine. Jason Quote
