Heads up display
silvadollaoneone
Does anyone know if the heads up display can be installed in EVERY 1995 Pontiac Grand Prix? If so... any idea where to find the wiring?
I have a base base base SE, and when I went to install it, the wiring was directly behind where the left side cubby hole was after you pull the bezeling off. It's wrapped in foam and electrical tape, but both the DIC and HUD pigtails are there.
What he said. Mine was way the hell back there. Try pullin off the side access panel if you cant get to it thru the lil cubby.
Guest Anonymous
My GT had the wiring. Mine was visible as soon as you pulled out the cubby. It had to be the easiest mod ever... i did mine in less than 10 minutes. Same for the DIC. even easier.
