dsgrntld187 Posted April 12, 2005 Author Report Posted April 12, 2005 Well if I junked it how would I have money for yours ? Quote
sonyman87 Posted April 12, 2005 Report Posted April 12, 2005 Give it a standard Tuneup Plugs Wires Filters write back with your results anyone think it may be intakes? Quote
JoroCorona Posted April 12, 2005 Report Posted April 12, 2005 The easiestway to check if its the ICM or the coils is to pull a plug wire and see if the car gets worse. It it only gets worse when pulling a plug from a particular coil, then its a coil. It it continually runs crap, its more then likely the ICM. A failed coil would only be intermittant if it was heat related. 95% of the time a failed coil will be a failed coil. Not intermittent. The ICM can cause an intermittent falure by failing to fire a coil everyonce in awhile. But the coil itself cant. Its either bad or good. NO middle ground. Quote
dsgrntld187 Posted April 14, 2005 Author Report Posted April 14, 2005 Give it a standard TuneupPlugs Wires Filters write back with your results anyone think it may be intakes? That fixed it. Plugs and wires and shes back to normal. Thanks for the suggestion Quote
