Crimson Fury Z Posted April 10, 2005 Report Posted April 10, 2005 heres a new problem; at idle and up to 3,500 rpms there is a constant put put put put. it dies down, but is still there after 3,500 rpm. #2 plug boot and plug were black w/ a gas smell, but the gapped end of the plug looked ok as far as i could tell. so i call the zone and they say that they got the rapid fire #12s in and when i got to get one they don't have any. so i had to get a bosch platinum(not the plat.4) and this didn't fix it. would this have anything to do w/ the 180 t-stat, running on the stock chip(till ben sends the ffp back)? Quote
GOT2B GM Posted April 10, 2005 Report Posted April 10, 2005 I ran a 180 t-stat all last year (with the stock chip) with no problems. :? Quote
Crimson Fury Z Posted April 10, 2005 Author Report Posted April 10, 2005 culprit: coil packs. only logical thing i can think of. #'s 2 & 4 plugs are the brown, but gas smelling goop on them, a clean up and reinstalled em. to better describe the putting, think of a go cart/4-wheeler putt to the rpms. Quote
joey b Posted April 11, 2005 Report Posted April 11, 2005 shouldn't it be 2 and 5 that are bad if it is coil packs? Quote
GOT2B GM Posted April 11, 2005 Report Posted April 11, 2005 How old are your wires? I'd try changing your coilpack(s) and get your ICM tested. Quote
Crimson Fury Z Posted April 11, 2005 Author Report Posted April 11, 2005 coil packs! replaced them and all is well(for now!!! :shock: ). wires are no older than 5 months, plugs, too, & the icm was done within the last 3 months. time for a cigar, if i had one :bawl: Quote
