rshissler Posted April 10, 2005 Report Posted April 10, 2005 I was just wonderin if the stuff worked or not. i was goin to use some in 2 6x9 boxes. it says to use 1 - 1 1/2 pounds to one cubic foot of box volume. thats alot Quote
JoroCorona Posted April 10, 2005 Report Posted April 10, 2005 Its mixed, it can hurt bass, but enchance mid and high range. Quote
rshissler Posted April 13, 2005 Author Report Posted April 13, 2005 i was told that the speakers would also sound like they are muffeled? spellin? Quote
rudefyet Posted April 13, 2005 Report Posted April 13, 2005 it's used to reduce the volume (in cubic inches) of a speaker box, so it all depends on the size speaker/box I'd check the speaker specs for enclosure size, measure the box, do some elememetry math and you'll know if you need to stuff it and how much Quote
veritasz34 Posted April 24, 2005 Report Posted April 24, 2005 Actually polyfill in a box will trick to driver into thinking it has a little larger volume to work in..The greatest advantage is the damping of unwanted resonance from the enclosure..It will help out on sealed enclosures but not in vented. You also do not want to stuff it full of this stuff..Just enough to fill the enclosure and still keep it's "Fluff".. It's greatest attributes are in the low to middle low active region.. Quote
