Removing radio
Guest Anonymous
I need to get the CD player out of the 92... does anyone know where the bolts are located? I took a peek in there, but didnt see anything.
i think its the same as a 1990, correct? if so, then open the glove box, and there are, i think 7mm hex screw, then under the seering colum, theres the dash part, under it, theres 7mm hex screws holding it in, take them out, then pull the dash peice out, be carful, it could break, but i doubt it, then theres another 7mm hex screw oposite side where the first one was. then the radio held in with washers, cause its mounted on top, then it should come out. i cant remember if theres 2 on each side of the plastic peice (u know where u open the glove box and dash peice) or not
