finding this is hard went to all the junkyards here with no luck is this a rare thing to to get? and can someone tell me what w- body i will find it on
thanks
You can find them on Cutlass Verts I think.. (Thats what mine was from Topless94).. I have it in my trunk right now.. You COULD always make one.. :wink:
If you are referring to the strut tower brace, yes, pretty hard to find. I found one on a Cutty vert.
Drew
^ and they work well on an FE1 car, dont do a lot on a FE3 car, just make it a little bit tighter.
Does the Cutty one on a FE3 car work better because that's the bar that was intended for it? Or are the results about the same?
The $18 ones aren't bolt-on, you can either drill your strut tower caps or buy bolt-on adapters from ZZPerformance. The latter is a much cleaner solution, but I think they charge $30 for their bolt-on adapters.
geez, there are too many posts about people wanting the GM STB.....A mod should just make a new topic w/the part number and make it a sticky or something.
