Water Pump
I got a 02 GTP and i was wondering how hard it is to put in a new waterpump?? She went out today not bad i cant still drive it and it doesnt get old its just sparying coolant. My buddies dad checked it out hes a GM tech, and he said its for sure the waterpump!! Any tips or anyone got any directions on how to do it. He said its a little more diffucult being thats it's supercharged!! Thanks
never pulled one on a sc'd but should be easier to get to than my riv would be. your buddies dad should be able to tell you how to do it but then again i should know too. post on clubgp if you dont get any good responses.
It was pretty darn easy on the 3100.. so if the engines are anything alike it shouldn't be too hard. *Get a Haynes manual* :wink:
1. Drain the cooling system. Refer to Draining and Filling Cooling System .
2. Loosen water pump pulley bolts.
3. Remove drive belt. Refer to Drive Belt Replacement in Engine Mechanical - 3.8L.
4. Remove the water pump pulley bolts.
5. Remove water pump pulley.
6. Remove power steering pump and reposition.
7. Remove the water pump bolts.
8. Remove water pump.
9. Remove the water pump gasket.
10. Clean and inspect the water pump mating surfaces.
Installation Procedure
1. Install the water pump gasket.
2. Install the water pump.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
3. Install the water pump bolts.
Tighten
* Tighten the long water pump bolts to 34 N·m (25 lb ft).
* Tighten the short water pump bolts to 22 N·m (16 lb ft).
4. Install the water pump pulley.
5. Install the water pump pulley bolts.
Tighten
Tighten the water pump pulley bolts to 13 N·m (115 lb in).
6. Install the power steering pump and the power steering bolts. Refer to Power Steering Pump Replacement in Power Steering Systems.
7. Install the drive belt. Refer to Drive Belt Replacement in Engine Mechanical - 3.8L.
8. Fill the cooling system. Refer to Draining and Filling Cooling System .
9. Inspect for leaks.
Detailed enough? :D
UPDATE: It wasn't the water pump, it was the radiator hose. I guess his Gatorback belt for his supercharger was rubbing against it and cut it like a band saw.
Wow that's wierd was the belt just stretched out alot?
Yah really, or the hose got moved in the way somehow.
I dunno. He just said that that's what it was.
