97cutlass Posted January 21, 2003 Report Posted January 21, 2003 Hi all!Haven't had much time to post or even browse this forum since I found it.Have to say though,it is a wealth of information & great job by all that contribute .Thanks! A new problem sprung up on my way to work yesterday.My ABS light came on.The brakes still seem to be working though.But,without ABS.With a snow/ice packed parking lot at work was easy to confirm that the antilock mechanism wasn't coming on when it should.Weird thing is ,when starting the car the Abs functions properly for the first minute or so then,light comes on & nothing. Anyone ever have a similar problem?Any suggestions on where to start would be greatly appreciated .Thanks. Quote
Guest RedCutlassSL Posted January 21, 2003 Report Posted January 21, 2003 Make sure your charging system is working properly. I had that same problem. Quote
crc Posted January 21, 2003 Report Posted January 21, 2003 Sounds like code-scanning time.. See if you can get a shop to scan the ABS codes for you.. It should be stored even if it doesn't come back on. Quote
Paul GTP Posted January 23, 2003 Report Posted January 23, 2003 Does the light comes on when you driving ? or when car is in parking. if the light comes on when you start driving, This may indicate wheel sensors problems (usually elecrical connectors).Had the same problem on my car Quote
97cutlass Posted January 24, 2003 Author Report Posted January 24, 2003 Actually,it comes on when parked or driving.Problem gone for 2 days but, came back tonight. Quote
GPRACER Posted January 24, 2003 Report Posted January 24, 2003 could still be a sensor or harnes. any abnormal wheel bearing noises? '97 has integral bearing/sensor Quote
hambone Posted January 24, 2003 Report Posted January 24, 2003 on my 'lude i had a similiar problem. it turned out to be one of the wheel speed sensors. it was fairly easy to check though. i think it required a resistance of between 500-900 ohms when checked at the harness connection. you should be able to get the specs for the gm here somewhere... Quote
