JJ77 Posted April 3, 2005 Report Posted April 3, 2005 When I crank my car up there is a very small amount of white smoke that comes out of the exhaust. I just noticed is because I shot a short vid clip of my exhaust, so when I get the new one I can give you guys a comparison between the two. If it makes any difference, both of my mufflers are blow to kingdom come and I run lots of lucus fuel additive. One more thing if anyone can host the vid for me that would be great. Quote
5speedz34 Posted April 3, 2005 Report Posted April 3, 2005 Is it when it's cold out, all cars put out white smoke because of water vapor when it's cold out. If it does it all the time you could have a headgasket leak. Which means it would be burning coolant, is your coolant always low? Quote
GOT2B GM Posted April 3, 2005 Report Posted April 3, 2005 Have someone start it for you and smell the white smoke when it starts. If its a "sweet" smell, its coolant related. Quote
JJ77 Posted April 3, 2005 Author Report Posted April 3, 2005 Well its not a sweet smell. I washed it yesterday and may have gotten a little water too close to the air filter Quote
5speedz34 Posted April 3, 2005 Report Posted April 3, 2005 So this is the only time it has done it? If so then just wait it out and see if it still is doing it later. Quote
1990lumina Posted April 3, 2005 Report Posted April 3, 2005 Also, when it is running, if you open your raditor and if the coolant has air bubbles coming up you have a leak in the system - and headgasket probably if you have white smoke from the exhaust. But you said it isn't a sweet smell so...could also be you might have gotten water in the exhaust when washing it the other day. - Jeff L. Quote
5speedz34 Posted April 3, 2005 Report Posted April 3, 2005 Like I said before give it a day and see what happens. Quote
93CutlassSupreme Posted April 3, 2005 Report Posted April 3, 2005 if it only does it when you start up and just for a minute, i wouldn't worry about it hell, my old '93 puffed blue smoke for a minute on start-up, which means burning oil, but it only did it for a minute at startup so i never worried about it, and my current '88 puffs black smoke for a minute at start-up, but it only does it for a minute so i don't worry about it Quote
JJ77 Posted April 4, 2005 Author Report Posted April 4, 2005 Thanks for the help guys so does anyone want to see the vid Quote
DiscoStudd Posted April 4, 2005 Report Posted April 4, 2005 If you have persistent white smoke, it could also be a sign of a bad master cylinder and/or power brake booster. If the MC is leaking into the booster, you can suck brake fluid into the intake manifold via the large vacuum hose that runs from the manifold to the booster... hell, my old '93 puffed blue smoke for a minute on start-upThat would be a sign of worn Valve Seals.and my current '88 puffs black smoke for a minute at start-upThat would be a sign of the injectors leaking out a bit of fuel after you shut the car off... Quote
JJ77 Posted April 4, 2005 Author Report Posted April 4, 2005 My brake fluid has been somehow disappearing, but like I said it is only at start up for a few seconds and only when the engine is cold. Quote
