Can I change JUST the TAIL LIGHT LENSES?
I remember once when I called a local GM dealer, asking about the 1992-1997 Cutlass Supreme tail lights(cause I want those ones for my 89), they asked me if I JUST needed the lense covers, or the whole thing?
I'm kinda confused about this...
Anyone know?
I would think he meant the whole thing. I bought the Cutlass 'aero' lights and spoiler (painted and installed), and look at the old ones for a possible clear light conversion: hel no. Those things are molded together and didn't want break them open.
But, I would double check the bolt patten and light bulb inserts. The 1992 - 1997 Cutlass rear lights have 5 studes that connect the lense to the body. What are you planning on doing? I've still have the orginals (intact and good condition)if you're interested.
- RedFox340
which year ones do you have cause my drivers side is messed up and i wanna put the newer style lights on mine with the oldsmobile thing in the middle so if them are the ones you have or the ones like the 89 style i might be interested name a price and i will get back to ya about it
You need the whole thing. 92-97 2dr taillights are glued together. It's either epoxy or ultrasonically welded, but either way it'd break them to try to get them apart.
88-91 2dr taillights are the only ones with removable lenses and are better made (thicker plastic).
so my tail lights i can take the lense off i thought i had to like almost break them to get them apart
It does take some force and it helps to know where the snaps are, but they do come apart.
I've had both lenses off of mine at one point.
