loominaz34 Posted April 1, 2005 Report Posted April 1, 2005 Hey all, i went to change my plugs yesterday and I found the #4 plug to get more difficult to turn the more I tried to loosen it. I'm basically positive it's cross threaded but is there any way to get the plug out without damaging the head now that it's in? I really want to avoid retapping my cylinde heads if I can at all avoid it. Quote
5speedz34 Posted April 1, 2005 Report Posted April 1, 2005 Wait, so is this the new plug or the old plug? If its the old plug I would think that all you did was strip the threads on it. If that's the case then try to get something back there to "grab" onto it. If it's the new plug it looks like you're going to have to heli-coil it. Quote
cutlsp Posted April 1, 2005 Report Posted April 1, 2005 if its a new plug your fucked. you will have to rethread the hole somehow this is why aluminum heads suck Quote
loominaz34 Posted April 1, 2005 Author Report Posted April 1, 2005 It's the old plug and the head of the plug that the socket goes onto is fine. I got the plug to loosen about 1/2 trn before it tightened up. I checked that I was turning the wrench the right direction about a million times and I was in fact loosening the plugs. Quote
cutlsp Posted April 1, 2005 Report Posted April 1, 2005 i think someone over torqued that plug man your fucked :? or they could have striped that spark plug hole and retreaded it Quote
GOT2B GM Posted April 1, 2005 Report Posted April 1, 2005 That happened on the #3 cylinder, on the back head of my moms old 96 Z34. We were doing head gaskets at the time so we had the machine shop remove the plug and helicoil the head. The heads were at the machine shop anyways to get resurfaced. Quote
