89SupremeCutty Posted March 31, 2005 Report Posted March 31, 2005 I have an '89 Cutlass Supreme w/ 3.1. I would like to know if its possible to change a cam while the engine is still in the car. Thanks for the help. Quote
R Dubya Posted March 31, 2005 Report Posted March 31, 2005 It has been done by drilling a hole in the fender well, just make sure its clean before you go sliding the cam through the hole. There is a writeup somewhere.. I could search for it but then again you could too Quote
89SupremeCutty Posted April 1, 2005 Author Report Posted April 1, 2005 I think I need a cam because when I open the throttle I can hear it backfiring through the intake. I want to buy an aftermarket cam, but I don't know how big of a cam i should go with. I wanna get some performance outta this car with out spending too much. I know alot about the Chrysler FWD cars and vans, but not a lot about GM cars. Thanks again for the help. Quote
Justin Posted April 1, 2005 Report Posted April 1, 2005 There's quite a few cams available for the 60*. I'd love to build my 2.8 up with either the ARI phase 2 cam, or the Crane 2020 compucam. http://www.engine-parts.com/GMV6/28camspecs.html Quote
89SupremeCutty Posted April 1, 2005 Author Report Posted April 1, 2005 you sure its not just badly timed? The motor runs perfect at all rpm's just backfires through the intake. I thought it was the cam but someone also told me it could be the lifters or a bad valve. Quote
JoroCorona Posted April 1, 2005 Report Posted April 1, 2005 Yeah, Cams general dont cause that kind of a condition. I'd check for leaky valves. Quote
