frank358fr Posted March 30, 2005 Report Posted March 30, 2005 Hi all, My car(Lumina 1992 3.1L) give me the code 23. I want to know what is the problem with that code. What I need to check or change on my car. I remove the Airbox to put a P-flow Code 23 Manifold Air Temperature (MAT) sensor- signal voltage is low or high Or TPS error Or Mixture control solenoid-open or short circuit problems Thanks Frank Quote
RacerX Posted March 30, 2005 Report Posted March 30, 2005 I think that's the intake air temperature sensor. Assuming you might have disconnected it when playing with the intake, did you reconnect it when you finished? Quote
frank358fr Posted March 30, 2005 Author Report Posted March 30, 2005 No I dont reconnect it because I remove the airbox to put a cone air filter. So what I need to do with that sensor(IAT)??? Thanks Frank Quote
White93z34 Posted March 31, 2005 Report Posted March 31, 2005 re install it. just drill a hole in the tubeing for the cone filter and shove the IAT from the old airbox inside and plug er in. Quote
frank358fr Posted March 31, 2005 Author Report Posted March 31, 2005 Where I drill a hole?? In wich tubeing?? Thanks Frank Quote
White93z34 Posted March 31, 2005 Report Posted March 31, 2005 do you have the cone filter directly connected to the throtle body? if not just drill a hole in the tubeing going from the TB to the cone filter Quote
