dohc v6 Posted March 29, 2005 Report Posted March 29, 2005 i have some new spring i bought the intrax one but they are not the same as the stock ones. now i went to dykz34 website but it does not work. so i need to know how to place them in the cushions so they dont rub or anything else. i need a response fast please Quote
GnatGoSplat Posted March 29, 2005 Report Posted March 29, 2005 The upper rubber cushion is keyed onto the upper mount and I don't think it should move much. The end of the spring needs to fit snug in the little ditch for it. There is a place for the bottom cushion to fit the bottom end of the spring too. You want the middle between the 2 "ears" on the bearing to be approximately centered on the same line that the edge of the spring sits in the upper rubber mount. I know my words probably don't make sense, it's not something I can explain without pics, and I don't have any pics here at work. Quote
dohc v6 Posted March 29, 2005 Author Report Posted March 29, 2005 ok so the plate that has the studs on it the spring should fit snug against that part and the bottom what should that be and how should the plate be located. because i f you have it wrong then it will clunk Quote
dohc v6 Posted March 29, 2005 Author Report Posted March 29, 2005 the top if i take the part that has the studs on it and bolt it up there then the spring should fit snugly against the rubber part the bottom does the spring fit in the little grove and the spring hit the end of the rubber like the front or is there a space my question is how to line up the metal baring plate that the bottom of the spring sits in . what should it be lining up with Quote
GnatGoSplat Posted March 30, 2005 Report Posted March 30, 2005 I will have to take a picture because I already tried to explain how the bearing lines up and I guess it didn't make sense. Quote
dohc v6 Posted March 30, 2005 Author Report Posted March 30, 2005 well now i am having a problem with the spring when it is under tension to have the bearing plate separate. basically the bearing plate does not stay flat as you rotate the assembely i dont know why this is and if it would even out after there in the car. Quote
Guest TurboSedan Posted March 30, 2005 Report Posted March 30, 2005 please post in the right sections. Quote
