slick Posted March 28, 2005 Report Posted March 28, 2005 The "chime through the radio" deal started when they switched over to the Double-Din sized radios (excluding the 95-01 Buicks and Oldsmobiles.) As far as installing an aftermarket radio in these cars, they sell a harness that allows you to relocate the radio to the trunk, but for the same money you can get an aftermarket chime module, which doubles as the "install harness" that you connect your aftermarket radio to. On the Impala (and I'd assume the Monte as well) you can reset the "Change Oil Soon" warning by switching the ignition on (engine off) and depressing the accelerator to the floor 3 times within 5 seconds. This is the "Chime Module" that I recently purchased for my Impala. Here are some FAQ's regarding late model Impala radios (which I'd assume would be the same for other GM's as well) Yep, we sell that relocation kit at work. You can opt out for it, but you will lose a few of the above mentioned things. Quote
