GTPrix Posted March 28, 2005 Report Posted March 28, 2005 Other than my steering wheel controls, is there anything I have to watch out for when putting in a new head unit? I know GM got cute at some point and started controlling differnet systems through the radio. I want to put a new Alpine h.u. in my 97 GTP. Thanx in advance for the input. Drew Quote
terryk2003 Posted March 28, 2005 Report Posted March 28, 2005 i think you should be fine in your 97...i think it was around 99-up when they started integrating other functions in... Quote
DiscoStudd Posted March 28, 2005 Report Posted March 28, 2005 The 97-03 GP's had the identical radios that the 94-96 GP's had. None of those model years used the radio to set the BCM functions (delayed locking, RKE settings, etc.) IIRC, in the 04-05 GP's, you set the BCM functions through the DIC. If you're looking to integrate the steering wheel controls, check this out: http://www.logjamelectronics.com/stwhcoin.html Quote
sl3196 Posted March 28, 2005 Report Posted March 28, 2005 Yup easy install! Do you have a bose system in there? Also I think in the gp's with onstar an aftermarket radio messes it up unless you get some kind of adapter. Quote
GTPrix Posted March 28, 2005 Author Report Posted March 28, 2005 I don't have the bose or on*, so I think the install should go smooth. Quote
Brian P Posted March 28, 2005 Report Posted March 28, 2005 What about the chime though? I thought that goes thru the radio. Quote
GTPrix Posted March 28, 2005 Author Report Posted March 28, 2005 Like when the doors are open? Isn't there something under the dash that controlls that? Quote
sl3196 Posted March 28, 2005 Report Posted March 28, 2005 What about the chime though? I thought that goes thru the radio. Doesn't on mine. I think it is the 04'+. Quote
slick Posted March 28, 2005 Report Posted March 28, 2005 What about the chime though? I thought that goes thru the radio. Doesn't on mine. I think it is the 04'+. Starting in 2000, GM started integrating it into the stereo's. I hate having to explain to people at work who drive a 00+ GM vehicle saying there may be a possibility of losing this and this, blah blah blah. Quote
digitaloutsider Posted March 28, 2005 Report Posted March 28, 2005 The GP's did NOT have it through the radios until the 2004 model year. Quote
slick Posted March 28, 2005 Report Posted March 28, 2005 Good to know. One less vehicle I have to worry about. I always have to ask the question "When you get your oil changed, do they have to mess with the radio to turn off the oil change light?" Quote
Brian P Posted March 28, 2005 Report Posted March 28, 2005 I thought I heard the chime coming out of the front speakers on my sister's '02. If not though that's good, cause she's been bugging me to put her CD player in. Quote
sl3196 Posted March 28, 2005 Report Posted March 28, 2005 What about the chime though? I thought that goes thru the radio. Doesn't on mine. I think it is the 04'+. Starting in 2000, GM started integrating it into the stereo's. I hate having to explain to people at work who drive a 00+ GM vehicle saying there may be a possibility of losing this and this, blah blah blah. I do have a 2000 there Chris. Quote
slick Posted March 28, 2005 Report Posted March 28, 2005 I thought I heard the chime coming out of the front speakers on my sister's '02. If not though that's good, cause she's been bugging me to put her CD player in. Most likely. If it has it integrated into the radio, it has(I know I'm missing some): Chime module, dome light, and oil change light. Those I remember for sure. Dan, like I said, some GM's have them, some don't. Hell... there have been a few 00+ GA's that came in with them, even a few cavy's. It all depends on the vehicle. Quote
digitaloutsider Posted March 28, 2005 Report Posted March 28, 2005 I thought I heard the chime coming out of the front speakers on my sister's '02. If not though that's good, cause she's been bugging me to put her CD player in. Most likely. If it has it integrated into the radio, it has(I know I'm missing some): Chime module, dome light, and oil change light. Those I remember for sure. Dan, like I said, some GM's have them, some don't. Hell... there have been a few 00+ GA's that came in with them, even a few cavy's. It all depends on the vehicle. The 97-03 GP's had the oil change light reset button under the dash. Quote
digitaloutsider Posted March 28, 2005 Report Posted March 28, 2005 I AM a plethora of useless information. Quote
sl3196 Posted March 28, 2005 Report Posted March 28, 2005 The 97-03 GP's had the oil change light reset button under the dash. Uh no. Mine's on the DIC. (maybe the DICless gp's (or the not as fancy ones) ) Chris, I have heard about cavi's having them intergrated but not the gp's. Quote
DiscoStudd Posted March 28, 2005 Report Posted March 28, 2005 The "chime through the radio" deal started when they switched over to the Double-Din sized radios (excluding the 95-01 Buicks and Oldsmobiles.) As far as installing an aftermarket radio in these cars, they sell a harness that allows you to relocate the radio to the trunk, but for the same money you can get an aftermarket chime module, which doubles as the "install harness" that you connect your aftermarket radio to. On the Impala (and I'd assume the Monte as well) you can reset the "Change Oil Soon" warning by switching the ignition on (engine off) and depressing the accelerator to the floor 3 times within 5 seconds. This is the "Chime Module" that I recently purchased for my Impala. Here are some FAQ's regarding late model Impala radios (which I'd assume would be the same for other GM's as well) Quote
digitaloutsider Posted March 28, 2005 Report Posted March 28, 2005 The 97-03 GP's had the oil change light reset button under the dash. Uh no. Mine's on the DIC. (maybe the DICless gp's (or the not as fancy ones) ) Chris, I have heard about cavi's having them intergrated but not the gp's. Ah, shit. I'm thinking of the tire pressure light. DOH! Quote
sl3196 Posted March 28, 2005 Report Posted March 28, 2005 The 97-03 GP's had the oil change light reset button under the dash. Uh no. Mine's on the DIC. (maybe the DICless gp's (or the not as fancy ones) ) Chris, I have heard about cavi's having them intergrated but not the gp's. Ah, shit. I'm thinking of the tire pressure light. DOH! What tire pressure light? (I know some 97's have them but mine doesn't) Quote
digitaloutsider Posted March 28, 2005 Report Posted March 28, 2005 It should be on your DIC. My buddy's '02 GTP has one. I guess the tire pressure monitoring system is an option. Quote
sl3196 Posted March 28, 2005 Report Posted March 28, 2005 It should be on your DIC. My buddy's '02 GTP has one. I guess the tire pressure monitoring system is an option.Weird. I've never seen one there on any gp. Got a pic? Quote
digitaloutsider Posted March 28, 2005 Report Posted March 28, 2005 Wow.. maybe they did drop the pressure monitor. I SWEAR his has it though. I'll have to get back to you. Quote
