Guest Anonymous Posted March 27, 2005 Report Posted March 27, 2005 Would a factory 92 CD player work with the SWRC on a 92 tape deck setup? Also, how do you remove the decks in cars of this vintage? Quote
digitaloutsider Posted March 27, 2005 Report Posted March 27, 2005 Yes. They used the same SWRC units. If they don't look the same, just swap the button pad itself over. It'll work. Remove the driver side kneeboard (3 or 4 7mm screws). Open the glovebox and wiggle the hinges to allow the door to swing all the way down. Remove the four 7mm bolts that hold the HVAC/Radio/storage faceplate in place. Remove the 4 10mm bolts on the headunit itself. Pull it out, being CAREFUL to not rip the antenna connector. Quote
