RedCutlass Posted March 27, 2005 Report Posted March 27, 2005 I've decided that after I do all the cosmetic work to my car, I'm gonna give it some serious balls ...what's too much to pay for a 3800 w\or w\out a supercharger. I've got a buddy w\a killer garage, so labor's not a problem. But just in case his shop spontainiously combusts, how much would it be for professional intallation? Quote
SleeperRed90TGp Posted March 27, 2005 Report Posted March 27, 2005 If you have a buddy with a killer garage He shoul know the costs of both. Do a search. This topick comes up every day with all the would be hotrodders. Just type in 3800 and you will get more than you can read in a day. Jud Quote
Guest Anonymous Posted March 27, 2005 Report Posted March 27, 2005 yeah theres a ton of stuff on here about the 3.8 swap... alot of people have done it. Quote
Aaron Posted March 27, 2005 Report Posted March 27, 2005 But just in case his shop spontainiously combusts, how much would it be for professional intallation? If you are getting an L67, I'd get a fire extinguisher with it for that reason...lol Quote
sl3196 Posted March 27, 2005 Report Posted March 27, 2005 But just in case his shop spontainiously combusts, how much would it be for professional intallation? If you are getting an L67, I'd get a fire extinguisher with it for that reason...lol Aaron your so funny. Quote
Aaron Posted March 27, 2005 Report Posted March 27, 2005 But just in case his shop spontainiously combusts, how much would it be for professional intallation? If you are getting an L67, I'd get a fire extinguisher with it for that reason...lol Aaron your so funny. You saw it yourself, they have a fucking fuel rail connection right on top of the supercharger, which becuz of low efficiency isn't exactly cold either, don't tell me that isn't asking for a problem... But that blower does sound good...You make me want to click it again, and make me want to do a supercharged LQ1 Fiero all over again... http://www.whipplesuperchargers.com Quote
john99gtp Posted March 27, 2005 Report Posted March 27, 2005 But just in case his shop spontainiously combusts, how much would it be for professional intallation? If you are getting an L67, I'd get a fire extinguisher with it for that reason...lol Aaron your so funny. :withstupid: Quote
digitaloutsider Posted March 27, 2005 Report Posted March 27, 2005 I actually saw an L67 start smoking from the injectors at a mod day once.. 3800 performance! Quote
EurosportZ34 Posted March 29, 2005 Report Posted March 29, 2005 I'm gonna give it some serious balls a 3800 w\or w\out a supercharger [thinks to himself] don't say anything... Quote
Aaron Posted March 29, 2005 Report Posted March 29, 2005 I'm gonna give it some serious balls a 3800 w\or w\out a supercharger [thinks to himself] don't say anything... Yah I didn't want to say anything either...but we all know what is cycling through Aaron's head. Quote
sl3196 Posted March 29, 2005 Report Posted March 29, 2005 I'm gonna give it some serious balls a 3800 w\or w\out a supercharger [thinks to himself] don't say anything... (done humping your DOHC yet? ) Check out http://www.car-part.com for engines. Also go to club gp and pm Ed Morad, he should have everything you need to do a swap. Quote
brianteel Posted April 1, 2005 Report Posted April 1, 2005 Actually i have never had any problems and I have never seen anything like for all the swaps I have done. Both motors are very easy to install in the car. The stock DP from the 3800 pretty much bolts in. The biggest thing is the axles and wiring but all that stuff can be bought. I am in the process of making adapters so the swap is plug and play. If you want alot of info on it check out http://www.l67swap.com My self and alot of other people have gotten alot of information together. If you want to figure costs: Labor is going to be 1200+ and then parts is going to be about the same depending on what motor you choose. Quote
digitaloutsider Posted April 1, 2005 Report Posted April 1, 2005 RedCutlass, if you aren't getting an L67, don't bother swapping a 3800 in. The N/A 3800 for the most part is pretty ballsless. No where near as bad as the 3.1 of course, but a 3.4 TDC would walk all over an N/A 3800 with no problem. I'm considering the L67 swap in my Bonne, and if you do the work yourself, it should be well under $1500 for the complete swap. Quote
brianteel Posted April 1, 2005 Report Posted April 1, 2005 all i have to say is when you do the swap dont do it cheap do it right. I learned that the hard way and ended up spending alot of extra money and time fixing things that should have never happened Quote
GP1138 Posted April 1, 2005 Report Posted April 1, 2005 RedCutlass, if you aren't getting an L67, don't bother swapping a 3800 in. The N/A 3800 for the most part is pretty ballsless. No where near as bad as the 3.1 of course, but a 3.4 TDC would walk all over an N/A 3800 with no problem. I'm considering the L67 swap in my Bonne, and if you do the work yourself, it should be well under $1500 for the complete swap. I disagree strongly. I drove my friend's '04 Monte, with the N/A 3800 SII, and it was nowhere near ballsless. I doubt the 3.4 could beat it. Quote
cutlsp Posted April 1, 2005 Report Posted April 1, 2005 if he get a series 1 or series 2 3800 it will be ballsless. but the series 2 does have a turbo kit coming out he could get for it so it would not be ballsless. or if he wants he could try for the series 3 3800 which is a pretty stout engine. Quote
EurosportZ34 Posted April 2, 2005 Report Posted April 2, 2005 I doubt the 3.4 could beat it. please don't let this get into another 3.4 vs. 3800 battle ...cause we all know the 3.4 would kick some 12-valve a$$ Quote
brianteel Posted April 3, 2005 Report Posted April 3, 2005 I doubt the 3.4 could beat it. ...cause we all know the 3.4 would kick some 12-valve a$$ sure Quote
