92chevyeuro Posted March 23, 2005 Report Posted March 23, 2005 My 92 Lumina has almost 100,000 miles on it. Sometimes when I come to a stop it does not shift into first gear. I have to shift it manually into first. And it seams to have a whining sound when I accelerate. How long do these transmisions usually last? Quote
THe_DeTAiL3R Posted March 23, 2005 Report Posted March 23, 2005 Depending on how it's driven, and how it's maintained (if it's maintained) plays a major role in the life of a transmission. Although, some will live a long life even though they aren't taken care of. Probably best thing to do would have it inspected.. Quote
Canada Posted March 23, 2005 Report Posted March 23, 2005 How do you know its not downshifting into first? Doggy off the line? Quote
92chevyeuro Posted March 23, 2005 Author Report Posted March 23, 2005 I step on the gas and it just revs. Quote
sonyman87 Posted March 23, 2005 Report Posted March 23, 2005 sounds like a plugged filter. little or no fluid to the transmisison will make it just slip or wine. get a pan service and see if that helps btw i have 183xxx miles onmy 4t60e and its seen hell since 104,000 miles Quote
SleeperRed90TGp Posted March 23, 2005 Report Posted March 23, 2005 I would say your input sprag has gone south. When you manualy put it in first gear it engages the 3rd clutch and 3rd roller clutch which seems to overcome the free wheeling in first. For a while. Mine is doing the same thing as it has done twice before. This cannot be repaired in the car. If and when you do get it rebuilt make sure they replace it with bigger(wider) aftermarket input sprag assembly. Jud Quote
92chevyeuro Posted March 23, 2005 Author Report Posted March 23, 2005 Would anyone buy this trans? Its cheaper than having a trans shop rebuild mine. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33727&item=7962147303&rd=1&ssPageName=WDVW Quote
sonyman87 Posted March 23, 2005 Report Posted March 23, 2005 Would anyone buy this trans? Its cheaper than having a trans shop rebuild mine.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33727&item=7962147303&rd=1&ssPageName=WDVW wow. thats a steal! umm. 2 year warranty 24,000 miles, where is this company based??? Sounds lagitomate if you know how to contact them after the auction. dont forget you have to give them your old transmission or its another $350 Quote
1990lumina Posted March 23, 2005 Report Posted March 23, 2005 I don't think that tranny will work with your car...don't you have the older style called the 4T60?? That one of ebay is electronically controlled.....or was Chevy using 4T60E in the 92 Luminas already?? - Jeff L. Quote
dbtk2 Posted March 23, 2005 Report Posted March 23, 2005 I believe the first year of the 4t60e was '93, in a Lumina at least. Shawn Quote
sonyman87 Posted March 23, 2005 Report Posted March 23, 2005 I don't think that tranny will work with your car...don't you have the older style called the 4T60?? That one of ebay is electronically controlled.....or was Chevy using 4T60E in the 92 Luminas already?? - Jeff L. you are correct! btw i found that companies contact info http://www.squaretrade.com/dis/jsp/defaultEB.jsp;jsessionid=4ddysgv763?vhostid=daffy&stmp=ebay&disid=4ddysgv763&seal_id=084094229639&prefcode=cET Quote
92chevyeuro Posted March 23, 2005 Author Report Posted March 23, 2005 Mine is the overdrive trans in it. It is a smooth trans. Quote
dbtk2 Posted March 23, 2005 Report Posted March 23, 2005 Mine is the overdrive trans in it. It is a smooth trans. Yes, but its not the electronic version. It is the 4T60 (440T4), not the 4T60E. Basically the same tranny, just not electronic. Shawn Quote
THe_DeTAiL3R Posted March 23, 2005 Report Posted March 23, 2005 Mine is the overdrive trans in it. It is a smooth trans. Yes, but its not the electronic version. It is the 4T60 (440T4), not the 4T60E. Basically the same tranny, just not electronic. Shawn Look at the pan. It will either say 4T60 or 4T60-E on the bottem. Here is an example Quote
1990lumina Posted March 23, 2005 Report Posted March 23, 2005 Hopefully there won't be as much sludge in it though if you do change the tranny fluid first j/k C-BAD! - Jeff L. Quote
92chevyeuro Posted March 23, 2005 Author Report Posted March 23, 2005 The tranny fluid looks very clean. I think it may have been changed not too long agao. I just hope it wasnt flushed. Quote
92chevyeuro Posted March 24, 2005 Author Report Posted March 24, 2005 It does have the 4T60. I emailed that company and asked if they have any. Quote
