Now how can i do this???
Guest Anonymous
You need to pull your taillights out and set them somewhere to warm up. Preferrably in the hot sun, which you may have to wait until summer. When the sealant on them gets warm and gooey enough you should be able to pull the lights apart. Be very careful not to break the clips. Then pull the colored lenses out, carefully so nothing gets broke.
BTW, those are taillights from a 4-door. I seen a 2 door with those the other day. Even had the lightbar across the back.
the guy who did those lights put the screen stuff that is made for flourescent lights in there didn't he.....or at least someone that made their own clear tails did
Guest Anonymous
I know toastemcutlass used that stuff for his clear corner lights. Is that what you're thinking of?
