2fast Posted March 21, 2005 Report Posted March 21, 2005 I'm gonna install a new cd player in my 1990 lumina, and I hate using the aftermarket wiring harness/connector, so I was wandering if anybody knows what the stereo wiring is on my car? I need to know what color wires go where. For example black-ground, etc. Thanks, Jon Quote
maybe2fast Posted March 21, 2005 Report Posted March 21, 2005 nice name...if you have a Hayne's Manula or Chiltons it should have a wiring diagram for the radio Quote
cutlass1991 Posted March 22, 2005 Report Posted March 22, 2005 Here ya go. This is the stereo wiring for Luminas '90 to '93 Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 4" x 6" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue Quote
White93z34 Posted March 22, 2005 Report Posted March 22, 2005 why would you not want to use one, they make the installation go much easier and then you don't hack up your cars wiring. i see no good reason not to use one. Quote
cutlass1991 Posted March 22, 2005 Report Posted March 22, 2005 Yeah, I agree you should definitely consider using one. The only reason I could think not to use one would be because of cost. I know best buy charges $18 for one now, but I think walmart still has them for $10. That is $10 well spent too. Remember that the factory harness probably only has a few inches of length, so your basically going to be splicing wires in a tight area where you can barely see. With the adapter harness, you can do all your splicing on a work bench, then just plug it in. This makes soldering wires a lot easier. Quote
slick Posted March 22, 2005 Report Posted March 22, 2005 Yeah, I agree you should definitely consider using one. The only reason I could think not to use one would be because of cost. I know best buy charges $18 for one now, but I think walmart still has them for $10. That is $10 well spent too. Remember that the factory harness probably only has a few inches of length, so your basically going to be splicing wires in a tight area where you can barely see. With the adapter harness, you can do all your splicing on a work bench, then just plug it in. This makes soldering wires a lot easier. Yep, and thats exactly what I try to point out to customers who insist on cutting there harnesses off. Plus, what happens if you decide to put the factory radio back in after you have allready cut the plug? Good luck on that one. Quote
RenegadeZ Posted March 23, 2005 Report Posted March 23, 2005 http://www.Streetdreams.com/wires/ For anyone in the future with this problem. Spend the extra money to keep it nice & clean, its so much faster to connect, trust me, one day I was being an ass & cut my harnesses, now of course I have to "hard wire" it all. Quote
