frank358fr Posted March 20, 2005 Report Posted March 20, 2005 Hi all, The idle is not regular. Now my car give me the code 33(MAP sensor=signal voltage is high during engine idle. (Note: Engine misfire or unstable idle may cause this code). My car have a unstable idle. First question: Where is the MAP sensor(with pic if it possible) and second: What I need to do to repair the map sensor?? Thanks Frank Quote
GutlessSupreme Posted March 20, 2005 Report Posted March 20, 2005 The map sensor is located on a bracket on the back of the intake plenum crammed next to the firewall. Quote
no1kicker Posted March 20, 2005 Report Posted March 20, 2005 MAP is held on by one bolt (13mm I think) and a clip. Remove the bolt, then the clip, MAP comes right off. I don't think it's your MAP sensor. Code 33 means the MAP sensor is seeing low vacuum at idle. This can be caused by a loose vacuum line connection especially where the 4 lines go into the TB. I would check there first. Quote
Rushman04 Posted March 21, 2005 Report Posted March 21, 2005 hey i had this code just the other day, it is because of a vacum leak. the map sensor isn't getting a good vacum. Check the vacum lines. The map sensor vacum line on the tb is the one closes to the fornt of the vechile. There is a picture of the vacum lince on the raditor suport member. Quote
