what exactly does the resonator do??
as the subject said what exactly does the resonator do and what does the inside look ???? just hollow????
I think it is a perforated pipe inside surrounded by fiberglass matting. Its purpose is to tune the exhaust tone and take away the raspiness (sp).
^What he said..
It cancels out certain sounds..but basically does what was posted above. I believe most(all?) use the reflective principle to bounce sound waves against one another in order to cancel out certain sounds/frequencies. Do a google search on "Helmholtz resonators" and you'll find more information on them.
If you find a flow tech "purple hornies" glasspack and look inside, you will find the same scallop cuts as in quality motorcycle exhausts. At least the older ones. I haven't looked down many cycle pipes in the last 10 years.
It is a heavier steel and seems to be better than most packs. I've had mine on for nearly three years. I did paint it silver though.
I wonder if my 3100 would sound more like a 2.8 if the resonator was removed... :think:
I miss that sound.
