'92 cutlass supreme
when car sits over night or sits for a few hrs, trany won't go into gear right away. (takes approx 20 sec.) Fluid level and color are ok. any ideas what could be causing this??
Pluged transmission filter.
a pan service could give you a whole new story.
leak in the vaccuum somewhere, bad tranny modulator could do it. Does it shift normal after you get it running?
trany will not shift into any gear. yes once the trany is warm it works fine.
seems like the trany is stuck in neutral at first.
I have found, through "experiments" that redlining 1st/reverse w/o brakes or letting off the gas, for 15 minutes straight, makes 1st gear take a 45 minute power nap :lol:
