how can i clean my O2 sensor (i think)
Im having a problem with my O2 sensor (i think) there is a some hesitation when i try to accelerate uphill, i had a 91 grand am that had a similar problem, i found that O2 sensor easily and sprayed some carb cleaner on it to solve the problem, but where it the O2 sensor in my 91 lumina? btw its a 3.1 blah blah blah
thanks
Tony
on the rear exhaust manifold. You'll see one green wire going to it. However, I wouldn't clean an O2, just replace it.
Yeah..they aren't to expensive so you might as well just replace it
- Jeff L.
You can place the tip of it(if it's not obvious, this is the side located inside the exhaust piping) in the flame from a propane torch to "clean" it. Doesn't hurt to try this if you have a torch handy, other then that, it's usually best to replace it.
So which brand of Sensor would you recomend? I think my sensor is also bad, i get lots of hesitation when i try to pick up speed. It stops doing it once I reach about 40, It feels as if one of my Spark plug wires were bad. but I just replaced them not more than two weeks ago, for the same reason, I also checked the plugs and replaced them. Still, it does it. :?:
Check your coilpacks. I'd put money down that that's your problem.
:withstupid:
