hey turbo guys, can you ID this ?
like the subject, i'm just curious about this, because i picked it up fro free from my buddy
from what i can tell it's a Garrett T-10 with an internal wastegate.
well i got these pics.
i only posted this here because it's a turbocharger, and you guys'd know.
thanks.
I see the pics now
thats a baby turbo maybe from a Firefly or one of those 3 banger turbo GM's?
what do you intend on doing with this turbo?
Cornerdealy you may be able to get away with wasting space in the other sections but i doubt you will in here :lol:
Keep it up, should be good watchin
i have no idea what it's out of, my guess is a TGA or Turbo Sunbird...
i just need all the info/specs/lineage on this bad boy...
and i intend to turbo my 1994 SL1.
and if you ignore conrnerdealy he'll get bored... he told me himself. :shock:
they had Turbo Sprints, Geos, Swifts, and Fireflys, but they were still like in the 16's or 17's
That might be a "M-10" turbocharger I believe, I tried searching for some info, looks like they might have been on early 80's turbo Mopars that made around 142hp(at least, one size of the M-10 turbo made that amount of power on a 2.2 liter 4cyl...I think they were non-intercooled also).
the compressor housing reads "AIResearch M10"
yet the rest of the turbo is the dk. brown color, and is a garrett of some sort
the numbers on it are:
MJ1941
14411-17F01
466370-2
MJ1941
14411-17F01
466370-2
Garrett makes Airesearch or at least they used to be the same company(from what I've read).
M10 is the casting number, no matter it won't do any good on a TGP :roll: So go put it somewhere else :lol: . On a 3.1L it won't even make 8psi, not enough flow, actually it would be run off its map/overspeed if feed by our engine's exhaust! And NO, a 2.8 is not that much smaller, stick it on a motorcycle or wetbike or snowmo, bye.
Jeff M
Heh, that'd be perfect for the 1.3L on my Suzuki Samurai!
that's why it's going to go on my 1994 SL1 with the SOHC 1.9...
if it dosent work for me, Luke, PM me if you're seriously intrested.
