GTPrix Posted March 16, 2005 Report Posted March 16, 2005 This is probably a really stupid question, but in order to replace headlights in my 97 GTP, is the actual headlight all that I need? The stock one would just unbolt I assume? Drew Quote
GTPrix Posted March 16, 2005 Author Report Posted March 16, 2005 Yes...it was a stupid question... :oops: Quote
supreme_style21 Posted March 16, 2005 Report Posted March 16, 2005 Your replacing the assembly? Or the bulb? The assembly is obviously bolted in.. The bulb simply twists out of the rear of the assembly. Quote
luminator94 Posted March 20, 2005 Report Posted March 20, 2005 Not that simple in a TrailBlazer though! You have to pull the whole front end off to change the bulb!! Quote
GP1138 Posted March 20, 2005 Report Posted March 20, 2005 Not that simple in a TrailBlazer though! You have to pull the whole front end off to change the bulb!! That would = me not buying that car Quote
EurosportZ34 Posted March 20, 2005 Report Posted March 20, 2005 Not that simple in a TrailBlazer though! You have to pull the whole front end off to change the bulb!! same on my Blazer for most of the front bulbs....sucks! although i believe we are talking about a Prix here, and it should be the same to change them as with any first gen W i believe Quote
5speedz34 Posted March 20, 2005 Report Posted March 20, 2005 Not that simple in a TrailBlazer though! You have to pull the whole front end off to change the bulb!! I know I have changed the bulbs on our envoy and if IIRC- the lense pops out and the bulb is right there. Right? Quote
