dohc v6 Posted March 15, 2005 Report Posted March 15, 2005 i have a 92 z34 speed and the injectors are shot. can i install the slp lt1 injectors or will it ruin something Quote
dbtk2 Posted March 15, 2005 Report Posted March 15, 2005 I would imagine (although I'm not sure because I don't know the size of the LQ1 injectors) that it would be fine but would just run rich. But, ask some LQ1 owners before taking my advice... Shawn Quote
dohc v6 Posted March 15, 2005 Author Report Posted March 15, 2005 they are 19 lbs stock if i am correct and 25 lbs for the slp kind. Quote
dbtk2 Posted March 16, 2005 Report Posted March 16, 2005 LT1 injectors stock are 24lb. So, going to 24 or 25lb. injectors from 19 shouldn't be that bad...it will probably run a little rich but I would imagine the 02 sensor would see this once the car warmed up and it would lean it out. You would probably only have a problem in open loop. Shawn Quote
