HokemBokem Posted March 15, 2005 Report Posted March 15, 2005 I know how to change the front pads and just did so a couple weeks ago and my back pads are about to hit metal so they are due for a change. I dont have my Chilton on me and was wondering what was the extra step to change the rears? Thanks Quote
mfewtrail Posted March 15, 2005 Report Posted March 15, 2005 You need to screw in the caliper piston instead of simply pushing it on on the rear calipers. This can be accomplished with needle nosed pliers if you don't want to buy the specialty tool for this purpose. Quote
HokemBokem Posted March 15, 2005 Author Report Posted March 15, 2005 You need to screw in the caliper piston instead of simply pushing it on on the rear calipers. This can be accomplished with needle nosed pliers if you don't want to buy the specialty tool for this purpose. Now the main thing Is it a bitch? comon i know it is Quote
GP1138 Posted March 15, 2005 Report Posted March 15, 2005 Why don't you try it and find out? What good's asking about it going to do? Quote
HokemBokem Posted March 15, 2005 Author Report Posted March 15, 2005 RossGT version 2.0 dont get it ANyway I would kinda like to know if there was any special tools/ anything else I need. I just dont want to go outside and jack my car up take the wheels off to find out theres something I need and I have to take my car to go get it. Im so sorry for asking. Quote
pwmin Posted March 15, 2005 Report Posted March 15, 2005 thats the only tool you need and if you have it, the job is easy, Quote
slick Posted March 15, 2005 Report Posted March 15, 2005 thats the only tool you need and if you have it, the job is easy, Using a pair of plyers was fairly easy as well. Quote
HokemBokem Posted March 15, 2005 Author Report Posted March 15, 2005 Allright well it looks like im going to get this done this weekend when I get paid. Does it matter if I get the cheapest shit for the rear brakes? I have pretty good stuff up front Quote
z34_nut Posted March 15, 2005 Report Posted March 15, 2005 its your rear brakes we're talking about so no, you don't need super expensive brute stops in teh back, edspecially on your stock regal. as for the tool, go to napa, or your local parts store. ask for the "rear caliper tool for vehicals equipped with a caliper mounted parking brake" it shouldn't be more then 10-20$ and it clips on to the end of an 1/2" ratchet. as for brake pads, i would buy BONDED brake pads, rivets dont last as long, and I've never had luck with them. if you have any more questions you can im me if you want. Quote
HokemBokem Posted March 15, 2005 Author Report Posted March 15, 2005 its your rear brakes we're talking about so no, you don't need super expensive brute stops in teh back, edspecially on your stock regal. as for the tool, go to napa, or your local parts store. ask for the "rear caliper tool for vehicals equipped with a caliper mounted parking brake" it shouldn't be more then 10-20$ and it clips on to the end of an 1/2" ratchet. as for brake pads, i would buy BONDED brake pads, rivets dont last as long, and I've never had luck with them. if you have any more questions you can im me if you want. That should be good. Is it worth it to buy the tool or do needle nose pliars work just fine? Quote
GP1138 Posted March 15, 2005 Report Posted March 15, 2005 its your rear brakes we're talking about so no, you don't need super expensive brute stops in teh back, edspecially on your stock regal. as for the tool, go to napa, or your local parts store. ask for the "rear caliper tool for vehicals equipped with a caliper mounted parking brake" it shouldn't be more then 10-20$ and it clips on to the end of an 1/2" ratchet. as for brake pads, i would buy BONDED brake pads, rivets dont last as long, and I've never had luck with them. if you have any more questions you can im me if you want. That should be good. Is it worth it to buy the tool or do needle nose pliars work just fine? I've always used plyers myself. Quote
z34_nut Posted March 16, 2005 Report Posted March 16, 2005 if your a rookie, you will fuck up the piston on the caliper (by either rounding all the corners, or damaging this part all togeather) all w-body owners should won that block in my opinion, makes shit alot easier to me. Quote
ron350 Posted March 16, 2005 Report Posted March 16, 2005 Don’t think riveted brake pads are offered for a 96 Regal. Harbor Freight has a caliper compressing tool kit on sale for $20 at local store. It is a China knock off of the one Snapon sells so it may be junk. http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40732 Quote
z34_nut Posted March 17, 2005 Report Posted March 17, 2005 Don’t think riveted brake pads are offered for a 96 Regal. Harbor Freight has a caliper compressing tool kit on sale for $20 at local store. It is a China knock off of the one Snapon sells so it may be junk. http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40732 Napa brake pads baby, rivets from hell. Quote
joey b Posted March 17, 2005 Report Posted March 17, 2005 It's a 96, I believe you don't need the special tool. I believe that they compress just like the fronts. Quote
HokemBokem Posted March 25, 2005 Author Report Posted March 25, 2005 It's a 96, I believe you don't need the special tool. I believe that they compress just like the fronts. No they didnt btw But yea the job went by semi-smoothly. Me and my dad couldent use his needle nose pliars to compress the piston so we had to use pliars that barely fit and kept slipping off every 1/4 turn. But other than that it was pretty easy. Also does anyone have a link to that tool ur supposed to use that just goes on a rachet? Quote
ron350 Posted March 26, 2005 Report Posted March 26, 2005 Are you talking about the cube? http://lislecorp.com/tool_detail.cfm?detail=399 z34_nut I like that “rivets from hell”. I will stay away from those. Quote
HokemBokem Posted March 26, 2005 Author Report Posted March 26, 2005 Are you talking about the cube? http://lislecorp.com/tool_detail.cfm?detail=399 z34_nut I like that “rivets from hellâ€Â. I will stay away from those. Yes thats it! Do you guys think this tool will still work even though me and my dad kinda scrpaed up the circle where you turn it? Quote
