ATTN: Lumina owners!
If any of you Lumina owners have a center console, could you please measure the cubby hole in front of the shifter? Length, width, and depth please.
i would normally be able to get that information in a matter of minutes except my Lumina is stored in my dad's barn right now...and i'm sure that someone will be able to measure it before next week when i get out there to work on it.
:roll: damn snow
i would guestimate it to be about 4" in length, 3" wide, and prolly 3-4" deep.
do you want the inside hole measurements. and does it matter if its a 95 center console?
I could find out for you by 7 central tonight... unless someone else posts first. So do you want em to remove the cubby and measure..or just the inside of the cubby?
- Jeff L.
Damn you said 91-94..mine is a 90..but heres the numbers anyway
Height = 2"(measured on the corners of the cubby)
Height = 2.25" (measured to the very tip of the middle...it is curved a bit and the highest point is the middle)
Length = 3.5"
Depth = Just about 3.5"
EDIT -
Here's a pic with the dimensioning in it..sorta sucks but its was a quick job!
- Jeff L.
