pwmin Posted March 11, 2005 Report Posted March 11, 2005 ever since i put it on, my belt has been moving to the right, off of the pulleys. has anyone had any problems with theirs doing this? Quote
Cornerdealy Posted March 11, 2005 Report Posted March 11, 2005 umm, did you buy a shorter belt? That's necessary when putting on a smaller pully... Quote
pwmin Posted March 12, 2005 Author Report Posted March 12, 2005 yeah, actually shorter than it says to (71") (gatorback); had a 71.5 inch (dayco polycog)before and did the same thing Quote
pwmin Posted March 12, 2005 Author Report Posted March 12, 2005 i think my harmonic balancer is going bad. i remember when i did the timing belt, the rubber part was coming out and i opted to not change it and check to see if it was ok. so hopefully that will fix it Quote
no1kicker Posted March 12, 2005 Report Posted March 12, 2005 ZZP makes a pulley for our cars? Didn't know that. Any more info? Quote
digitaloutsider Posted March 13, 2005 Report Posted March 13, 2005 I'm guessing he means the Bonneville in his sig. As far as I know, they make nothing for first-gen W's.. Quote
HokemBokem Posted March 13, 2005 Report Posted March 13, 2005 OHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH Quote
sl3196 Posted March 13, 2005 Report Posted March 13, 2005 I'm guessing he means the Bonneville in his sig. As far as I know, they make nothing for first-gen W's.. Bonneville? I see a riv in the sig but he talks about the timing belt so can't be the riv. I've never heard off zzp making pulley's for 1st gen's either. Quote
digitaloutsider Posted March 13, 2005 Report Posted March 13, 2005 Er Riv yeah. Sorry I was tired as hell last night. Quote
pwmin Posted March 13, 2005 Author Report Posted March 13, 2005 sorry for the confusion. its an ffp not a zzp sorry. and its for the gp. Quote
no1kicker Posted March 13, 2005 Report Posted March 13, 2005 In that case, make sure you tightened the pulley properly. Sounds like it might not be on all the way. Quote
RacerX Posted March 14, 2005 Report Posted March 14, 2005 It is the correct pulley for your LQ1, right? Not to say that you would order the wrong pulley, but you could have been shipped the wrong pulley. I don't know if a '91-'93 pulley would fit a '94-'97, except that they're offset is different, which might this. Don't know how noticable it would be when installing the belt. Quote
pwmin Posted March 14, 2005 Author Report Posted March 14, 2005 im not sure of the difference, but i measured it and compared it to the stock pulley and it seemed to be the same dimensions (obviously except the diameter of the pulley) and i know its on the whole way but i think its the balancer, but i guess i have to get that from gm since pam/factory and the auto parts stores cant get it. Quote
