dhs1223 Posted March 9, 2005 Report Posted March 9, 2005 I need some help in locating the RKE receiver box in my 95 Cutlass Convertible. When I bought the car, it did NOT come with any key fobs. Found one on Ebay, insured power by installing fresh batteries. Grounded the connector in the trunk by the antenna, the locks and trunk release cycled, pressed a button on the remote, disconnected the jumper cable and NOTHING. I am assuming for now that the RKE receiver may be bad. Since I do not have a clue what it looks like, I am unable to identify it. Any references I have read as to location, indicate under parcel shelf or back window shelf. Well, a Cutlass convertible has no back shelf, therefore, I do not know where to look. Thank you in advance for your help, I don't want to tear my trunk apart looking for something I can't identify. Quote
GnatGoSplat Posted March 9, 2005 Report Posted March 9, 2005 If it's the same as a 94, it's a black plastic box mounted on top of that welded in framework between the wheel wells... I'm talking about that framework that houses the hydraulic pump for the top. Quote
jmblimo Posted March 9, 2005 Report Posted March 9, 2005 Did the locks cycle when you pressed the button on the remote while the connector was grounded? If not, it sounds like the remote is bad. Quote
dhs1223 Posted March 9, 2005 Author Report Posted March 9, 2005 Thanks for the info on what to look for. And, NO, the locks did not cycle when the button was pressed on the remote, however, if the RKE receiver box is bad, then how would I know if the remote is good or not?? I will keep plugging away at it. Thanks Quote
supreme_style21 Posted March 9, 2005 Report Posted March 9, 2005 When you ground it, it should cycle before any buttons are pressed. Quote
jmblimo Posted March 9, 2005 Report Posted March 9, 2005 He said it did cycle when the connector was grounded. I don't know if that proves the receiver is operating but that would push me toward thinking that the remote is the problem. You need another one to be sure. You'll need two anyway! Quote
supreme_style21 Posted March 10, 2005 Report Posted March 10, 2005 He said it did cycle when the connector was grounded. I don't know if that proves the receiver is operating but that would push me toward thinking that the remote is the problem. You need another one to be sure. You'll need two anyway! Gotcha.. Remotes for sure. Quote
