I have decided I am going to keep my cutlass for what is now about the 3rd time, so a couple questions, I found these disks on ebay, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7951954399&category=33564
they are for a 88-93 grand prix, will these disks fit on my 1993 cutty Supreme coupe? also, does it matter whether I get the 88-93 or the 94+ disks?
and the wheel lugs on w-bodies are 5x114.3 correct or are they 5x115 and are the two interchangeable?
And, finally, does anyone have links to a company that sells struts/springs/leaf for the back? my mono leaf is shot I think because I hear a popping noise when hitting bumps in the road when the suspension bottoms out, and the car bounces like mad. any help is appreciated.
Yes, 88-93 Grand Prix discs will fit a Cutlass.
You cannot use 94+ rears.
Bolt circle is 5x115mm, 5x114.3 will usually fit.
You need a new spring bushing, there are many threads on that, try a search.
If the car bounces like mad, that's the damper (strut), not the spring... springs bounce, dampers stop them from bouncing...
Mike
