eclipse5302 Posted January 17, 2003 Report Posted January 17, 2003 Hey guys! I want to put a FAQ section on my site. Basically, this is what I've got so far: ------------------------------------------------------------------------------ can I use a MBC? Can I use larger injectors? Can I use a larger turbo? Can I install a 5speed? Can I clear out the ac fins for more ic flow? what does the a/r thing mean? Can I use g3 heads? CAn i run a larger ic? should i p+p my heads? what should i do to my tgp to freshen it up? why does my car burn oil or smoke? my car doesn't start! how can i add more fuel? can i defeat the boost cutoff? i want a chip for more boost! why does my tgp stall when coming to a stop? common tgp problems: does my crossover leak? do i need to replace my o2 sensor? should i replace my air filter? -------------------------------------------------------------------------- Anyone have any suggestions for other topics? Thanks in advance. Jason Quote
TGPilot Posted January 17, 2003 Report Posted January 17, 2003 I think you should incorporate a TGP performance chip area as well!! That way everyone can learn along the way without it costing an arm and a leg!! I am more than willing to erase and burn chips for folks if they want to try it. No cost except shipping to them... 8) Quote
twalt13 Posted January 17, 2003 Report Posted January 17, 2003 looks like all the questions I have asked you already (Jason) May want to add some suspension performance items like the lowering springs, sway bars, other options for STB's, etc. Thomas Quote
