94 3100 grand prix aftermarket
Can anyone tell me where i can get an air box and any web sites for parts for my 1994 se ? ...aftermarket that is
No one actually makes an aftermarket airbox (such as Wizaired). You're better off creating your own CAI if that's what you're looking for. I'm guessing you have a 3100. There's not much aftermarket for that, either.
I've learned quite quickly any mods you wanna do you pretty much have to make yourself lol
- Jeff L.
Go dig around at http://www.60degreev6.com
You can wake up that 3100 by swapping the upper and lower intake, along with the heads from a 97-99 GM Minivan 3400.
If you want to really step up in the power dept, swap in a 3400 (you'll need an upper intake manifold from a 97-99 Minivan and an EGR adapter from the 60degreeV6.com store.)
Here's the site that'll show you how to do the 3400 swap.
lol I love how one of the only mods to do with our engine is to swap in parts from a minivan
Or an Alero in my case. :lol:
You're gonna need a (97-99) Minivan UIM in order to get your EGR to work, unless you have the PCM reflashed to delete the EGR altogether :wink: ...
'99 Alero/Grand Ma parts will have the same EGR as the '96-99 vans.
Thank you, I was about to scream there... :willynilly:
EDIT: Now that I think about it, this is from a 2001 Alero. Will that make any difference?
Well yeah, but lemme tell ya something. Either EGR style you'll need an adapter. Both are readily available to convert a '96-99 manifold, or a '00-03 Manifold. So either way you'll need an adapter ranging from $45-100
Does anyone make adapters for the 00-03 manifolds yet?
Yeah, I knew that much. I'm prepared for that, sorta. I might have to wait awhile to convert the EGR.. I'm not sure what I'm gonna do, because I won't have the cash to get the EGR adapter until Thursday, but I'll need it by like Friday, so there's really not time to wait for it. I have to have this completely done by Monday.
I'm not sure exactly what I'm gonna do.
Just make a blockoff plate for now and bolt it down. With your computer, you will get a check engine light occasionally (usually after being on the highway a while) but if you shut the engine down, and restart, the light won't return for a while. It's not like OBD2 when the light stays on.
Well, I obtained an EGR valve from a 3400 UIM to use as a block off for now. I'll leave that on until I get an adapter from 60*V6.
